Open
Disable feature caching on specific output ports
Related products:FME Form
k_murai
toby_c
mkludas
leo.at.ls
+89
  • assalamiali
  • k_murai
    k_murai
  • toby_c
    toby_c
  • mkludas
    mkludas
  • leo.at.ls
    leo.at.ls
  • cbell_lvs
  • cshepard
    cshepard
  • User1682409324637385798
  • siennaatsafe
    siennaatsafe
  • david_r
  • nielsgerrits
    nielsgerrits
  • ebygomm
  • redgeographics
  • takashi
  • virtualcitymatt
    virtualcitymatt
  • geomancer
    geomancer
  • danilo_fme
    danilo_fme
  • dustin
    dustin
  • sigtill
    sigtill
  • tcrossman
    tcrossman
  • vxn43
    vxn43
  • bwn
    bwn
  • carmijo
    carmijo
  • tomf
    tomf
  • bruceharold
    bruceharold
  • dbaldacchino1
    dbaldacchino1
  • larue
    larue
  • lars_de_vries
    lars_de_vries
  • nic_ran
    nic_ran
  • kennyo
    kennyo
  • chriswilson
    chriswilson
  • jackyd
    jackyd
  • canerakin
    canerakin
  • arthur_bazin
    arthur_bazin
  • stefanh
    stefanh
  • juanmahere
    juanmahere
  • koenterralytics
    koenterralytics
  • gbj1717
    gbj1717
  • markw
    markw
  • revesz
    revesz
  • gerhard
  • kaylin.austin
    kaylin.austin
  • tomtoni109
    tomtoni109
  • cofk_cbell
    cofk_cbell
  • k_lander
    k_lander
  • mik_w_thomsen
    mik_w_thomsen
  • jnotter
    jnotter
  • stefan.vdberg
    stefan.vdberg
  • carstenotto
    carstenotto
  • geolassi
    geolassi
  • littlefictions
    littlefictions
  • cwinfield
    cwinfield
  • mvanwie
    mvanwie
  • dwhitworth-cop
  • mp3robbo
  • mygis
    mygis
  • xabi
    xabi
  • map_maker
  • gsri
    gsri
  • tvl
  • ecthelion
    ecthelion
  • whkarto
    whkarto
  • amdubois
    amdubois
  • maayke
    maayke
  • johnt
    johnt
  • germang
    germang
  • crutledge
    crutledge
  • becchr
    becchr
  • bubblebeb
    bubblebeb
  • mhab
    mhab
  • darkspatiallord
    darkspatiallord
  • jakethepainter
    jakethepainter
  • anari
    anari
  • jacklonsdale
    jacklonsdale
  • frro
    frro
  • geoportalcartog
    geoportalcartog
  • geoal
    geoal
  • paul_m
    paul_m
  • mechomicky_bmcd
    mechomicky_bmcd
  • raymondbrunner
    raymondbrunner
  • stevenjh
    stevenjh
  • maplinux
    maplinux
  • soeren
    soeren
  • osarhan
  • newaygogis
    newaygogis
  • jkerssens
    jkerssens
  • firework_girl
  • amanda
  • treborq
  • josefant
  • hbl
  • DanAtSafe
    DanAtSafe
  • tkaufmann
    tkaufmann
  • bpallares
    bpallares
Allow certain output ports to have their feature caching disabled to improve performance.
As an example, I quite often use the FeatureMerger. With Feature Caching turned on it will cache all the output ports, as described here under the 'Unconnected Output Ports' heading - https://knowledge.safe.com/articles/79739/feature-caching-and-performance.html - I often don't care about the UnusedSupplier and UsedSupplier, but they tend to be the largest datasets and add significant time on first run/uncached runs.
What would be ideal is an option to turn off the feature caching for certain output ports, perhaps under the right click menu of the output port itself.
Admittedly this right click menu only appears once the feature caching is done, but you get the idea.
This is similar to this proposal - https://knowledge.safe.com/content/idea/77431/feature-caching-woes-reuse-large-attributesturn-so.html - But a bit more granular, whereas that proposal suggests allowing feature caches to be turned off for entire transformers, this one proposes only turning them off for certain output ports.
  • May 10, 2019
I was going to make the same suggestion but found your post first. The StatisticsCalculator is also a good example. The Cumulative output is rarely used but doubles the amount being cached for that transformer.
stevenjh
  • June 5, 2019
I'll add another example to this, the SurfaceModeller, I've had a workbench spend all night trying to make the unconnected voronoiDiagram after I switched from a subset to a full dataset.
It made me think that ouputs could be considered Filters, Manipulators, or Creators/Generators, and don't cache the unused Creators/Generators as they require additional processing.
dbaldacchino1
Forum|alt.badge.img+11
As a matter of UI efficiency and related to this idea, sometimes I want to turn on feature caching only on a specific transformer/s. For example if you have a really big workspace, you might want to enable feature caching just on a few transformers towards the end. In that case it would be valuable to have an option to disable caching at the workspace level, and then selectively pick which transformer and ports you want to enable feature caching on. Yes, fine granular control is what I'd like :)
carmijo
  • September 23, 2022
good point. you could use inlinequerier to pull stats and only get out what you want but i understand the need for a no-code solution
carmijo
One potential reason this isn't gaining traction - wouldn't this require you to re-run the transformer if no features are being cached from a port that passes features for further processing?
nordpil
Forum|alt.badge.img+10
  • April 22, 2024
To reduce feature caching, one can always minimize bookmarks, that way feature caching only happens on the input/output ports (to the bookmark)
LizAtSafe
Forum|alt.badge.img+15
  • April 5, 2025
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
