I'd like to do some customization of the FME Server Web User Interface and I wondered if other people also want to do that? What would you like to customize in the Web UI?
Great idea! I'd like to be able to "publish" a very simple jobsubmitter form for a specific workspace, making it easy for end users to start a job without a username/password or even knowing anything about FME Server at all. Ideally it should be possible to translate / localize the form text, but it's not a deal-breaker.
The form should be very minimal, e.g with only the following elements that should all be customizable:
- Header
- Short text description (markup?)
- Published parameters
- Submit/reset-buttons
- Maybe a tiny footer where you can put a custom disclaimer or contact info
Localization would be nice, a custom logo or header too.
Ability to add background maps as in FME Data Inspector for user inputs to workspaces along with forms will be of additional interest to me.
A tutorial on how to set up a basic custom web page to run a workspace on FME Server would be a nice start. I think I can cobble together something by looking at the Developer Playground but it would still require some trial and error.
- you could define what fields/columns and in which order are shown in various listings
- you could sort list by any visible field
- you could filter what is shown
then yes, I'd like that too !
Being able to override the color of the left side menu background to distinguish e.g. TEST and PROD servers would be fantastic.
I am with @david_r just a simple way of changing the skin to be able to tell different environments apart. ie. DEV TEST PROD.
Some parts are changeable now but a more simpler approach would be nice
All the votes have been transferred into this idea.
