New
Custom Log Filter
Related products:FME FormFME Flow
  • August 21, 2025
  • 46 views
ax_pflegpeter
Currently you can filter Logs by severity level: Information/Warning/Error. I would love to have an additional filter that is user defined. For instance, I often use Loggers to write messages to the log that are used for debugging purposes, like “Token successfully fetched” or “45 Features written to DB”. Technically these messages should be categorized as “Information” but Information type log entries are hard to filter as most messages have this log type. On the other hand I don’t want to to use the Warning or Error type, as these messages should not be mixed with real errors.
That’s why I propose a new Log Message type that could be called “User” or “Custom”. Like the other Log Types User Logs should be color coded and filterable on both Form and Flow.
sammy
Forum|alt.badge.img+27
  • June 2, 2026
Can we please in general bring back the regular Log Message Filter options as well… they seem to have been removed as I do not see them in anything newer than 2024.2
