Archived
CRCCalulator: MD5 algorithm also with geometry
Related products:Transformers
  • August 15, 2018
  • 7 replies
  • 92 views
bradr
Forum|alt.badge.img+9
Because the default CRC-32 algorithm occasionally returns duplicates I use MD5.
I noticed that MD5 does not uses geometry.
  • August 15, 2018
Which FME version is this? Seems to work fine with FME 2018.1
bradr
  • August 15, 2018
2018.0.0.2
bradr
  • August 21, 2018
Tested in 2018.1.0.1: same problem.
@david_r: in CRCCalculator use _creation_instance as attribute and you get the duplicate. Change MD5 to CRC32 and it works fine.
bradr
  • August 21, 2018
@david_r : in CRCCalculator use _creation_instance as attribute and you get the duplicate. Change MD5 to CRC32 and it works fine.
crccalculator-md5-no-geometry-v2018101.fmw
bradr
  • August 13, 2020
In 2020.1.0.0 still not corrected. When using Selected Attributes Geometry is not used, resulting in duplicate crc value. Only when using MD5
bradr
  • May 25, 2022
David, you did not include the _creation_instance attribute in the CRCCalculator.
In 2022.0 issue still present
  • October 4, 2022
Same problem in 2021.0. Works if no selected attributes. But when adding one or more attributes geometries is no longer used when the MD5 is calculated.
