Using Python in PythonCaller or Python scripts of parameters does not allow easy commenting of code by calling a shortcut/hotkey on a block of code yet. This is possible in other IDE's such as Visual Studio Code with CTRL + /. Currently there is a workaround by putting # in front of every code row, but this can be quite tedious if you want to comment out a whole block of code with 20 rows.
Archived
Comment out block of code in FME via keyboard shortcut
