Open
Bulk AttributeValueMapper
Related products:Transformers
  • February 28, 2018
  • 105 views
It would be good to replace the attribute value mapper with a ‘bulk attribute value mapper’ tool that could do the following:
1. Instead of importing data and it being static - it would be good for the tool to reference a db table/file dynamically so as to always pull in the latest data.
2. Instead of only handling one attribute at a time, it would be good to update multiple attributes at once from multiple lookup locations.
Source AttributeDatabase/FileFeatureTypeLookup Code AttributeLookup Value Attribute
MATERIALOracle GIS_DBLU_MATERIALLCODELVALUE
BEDDINGBeddingLookup.xlsxSheet 1CodeValue
In this example the Material AC would be value mapped to Asbestos Cement and the bedding type SND would be value mapped Sand
I understand that this can be done at the moment using a series of feature mergers with process duplicates enables, but this is something that comes up quite frequently as we have multiple datasources that only store the codes and regularly need to be updates to have the description field.
lars_de_vries
Forum|alt.badge.img+10
I would use a DatabaseJoiner for the use case you describe. Now you would need multiple DatabaseJoiners.
I would suggest BulkAttributeValueJoiner as the transformer name.
mel
Forum|alt.badge.img+7
  • January 28, 2021
I just need a simple one where you can have the same list apply to multiple fields and update the values in the field being looked at. I just finished copying the Attribute value mapper 15 times to apply the same list to multiple fields to replace the value in the field. The string replacer doesn't work with the data issue we are having to fix.
bark0s
Forum|alt.badge.img+4
  • July 1, 2025
Being able to populate the left hand side, the “Input Value” from the feature cache would be very sensible.  It’s so sensible that it should be fundamental.  Being able to then group those values, and make multiple groups would be great also.  So that I could then map n values in group 1 to a, n values in group 2 to b, etc.
I don’t know whether that makes it a bulk attribute value mapper but the existing AttributeValueMapper is screaming out to populate Input Value from Cache.  It’s confounding that it isn’t included functionality already.
