Open
AttibuteManager: Rename attribute "sub-properties" (attr.hyperlink, attr.formatting, etc.) alongside the attribute itself
Related products:Transformers
  • November 28, 2024
  • 20 views
danilo_fme
warrendev
sweco-senari
schlomm
peggym
+7
  • danilo_fme
    danilo_fme
  • warrendev
    warrendev
  • sweco-senari
    sweco-senari
  • schlomm
    schlomm
  • peggym
    peggym
  • duri
    duri
  • colin_a
    colin_a
  • chris_hvc
    chris_hvc
  • sibban
    sibban
  • anfo
    anfo
  • huguesb
    huguesb
  • rothc
    rothc
vlroyrenn
When using ExcelStyler early on in your flow (I use it to highlight invalid values in Excel fles right after the data has been read from my database) or any transformer that creates <attributename>.something “sub-attributes” (not sure what the actual name would be), you currently must make sure to manually rename all of those alongside the main attribute whenever you rename them through an AttributeManager or AttributeRenamed, otherwise they will not be observed by downstream writers and transformers. If the Styler is added in the later stages of building the flow, that means going through all downstream AttributeManagers one by one to make sure the newly added sub-attributes follow the main one.
It would be conveinient if those could all be renamed together automatically whenever the main attribute is renamed.
LizAtSafe
Forum|alt.badge.img+15
  • April 5, 2025
NewOpen
danilo_fme
Forum|alt.badge.img+45
  • April 16, 2025
LizAtSafe wrote:
NewOpen
Thanks for update.
