Released
Allow writing of empty tables - schema creation
Related products:Integrations
  • May 2, 2019
  • 7 replies
  • 232 views
chriswilson
Forum|alt.badge.img+29
I need to create a schema in geodatabase format and would love to use FME for this. To avoid writing null or junk features to the tables it would be good to be able to write out a schema without features. I know this defeats the very name of FME if there is no feature, but it would be useful.
On this occasion I'll play with the idea of writing out one feature per table then truncating them all, to achieve the same outcome.
erik_jan
Forum|alt.badge.img+26
  • May 2, 2019
Adding this as a checkbox option on the feature types would be helpful.
aarcra
  • May 22, 2019
bump - I'd like this as well. It would also help to be able to overwrite existing tables/feature services that previously had records, but may no longer. Without this ability, you have to read the existing table the attach delete keyword or use a creator to initiate the writer, to truncate with a blank record (which still needs to be read afterwards again to delete itself.
chriswilson
  • May 23, 2019
At present I think either truncating after creation or a shutdown python script to delete the feature is the way to go. A 'schema-only' setting on each writer/feature type would be ideal. currently
LizAtSafe
Forum|alt.badge.img+25
  • October 29, 2024
Open→In Development
LizAtSafe
  • October 29, 2024
Open→In Development
LizAtSafe
  • February 5, 2025
In Development→Released
LizAtSafe
  • April 5, 2025
This is now available in FME 2025.0
