Open
Add Support for OData Version 4.01
Related products:Integrations
  • July 21, 2025
  • 55 views
_fabian_
Forum|alt.badge.img+5
The OData Reader currently fails with the error “The version '4.01' is not valid.” when you try to retrieve data from an OData Version 4.01 Endpoint.
Full Log:
Creating reader for format: OData
Trying to find a PYTHON plugin for reader named `ODATA'
The workspace does not contain user Python. FME will attempt to use a Python 3.13+ interpreter
Using Python interpreter from `C:\Program Files\FME\fmepython313\python313.dll' with PYTHONHOME `C:\Program Files\FME\fmepython313'
Python version 3.13 loaded successfully
Loaded Python module `odata' from file `C:\Program Files\FME\python\fme-plugins-py313.zip\odata\__init__.pyc'
DEBUG: Configured logging for ODataReader
DEBUG: ODataCommon __init__()
DEBUG: Inspecting mapping file
DEBUG: Feature Geometry Priority: 'none'
DEBUG: Feature Type(s): 'ProductDescription,Product'
OData Reader: Performing client-side pagination with 1000 features per request
DEBUG: DEF line: ODATA_2_DEF ProductDescription odata_type odata_none FILTER_QUERY Language eq 'DE' ORDER_BY_QUERY EXPAND_QUERY fme_attribute_reading defined Product string ProductDescription string
DEBUG: Attributes: Product ProductDescription
DEBUG: Options: odata_type FILTER_QUERY ORDER_BY_QUERY EXPAND_QUERY fme_attribute_reading
DEBUG: DEF line: ODATA_2_DEF Product odata_type odata_none FILTER_QUERY ProductGroup eq 'ZS03' and IsMarkedForDeletion eq false ORDER_BY_QUERY EXPAND_QUERY fme_attribute_reading defined Product string
Retrieving connection 'SAP S4 Test'
Retrieving web service 'HTTP Authentication'
ODATA reader: Creating bulk features from individual features
Using MultiWriter with keyword `PRIMARY_DEST' to output data (ID_ATTRIBUTE is `multi_writer_id')
Writer output will be ordered by value of multi_writer_id
Loaded module 'LogCount_func' from file 'C:\Program Files\FME\plugins\LogCount_func.dll'
FME API version of module 'LogCount_func' matches current internal version (4.0 20240722)
DEBUG: urllib3.connectionpool Starting new HTTPS connection (1): my123486.s4hana.cloud.sap:443
DEBUG: http.client send: b'GET /sap/opu/odata4/sap/api_product/srvd_a2x/sap/product/0002/ HTTP/1.1\r\nHost: my123486.s4hana.cloud.sap\r\nUser-Agent: FME/2025.7.52.25241 python-requests/2.32.3\r\nAccept-Encoding: gzip, deflate\r\nAccept: application/xml,application/json\r\nConnection: keep-alive\r\nOData-MaxVersion: 4.0\r\nAuthorization: Basic XXX\r\n\r\n'
DEBUG: http.client reply: 'HTTP/1.1 200 OK\r\n'
DEBUG: http.client header: set-cookie: sap-usercontext=sap-client=100; path=/
DEBUG: http.client header: set-cookie: SAP_SESSIONID_Z5R_100=XXX%3d; path=/; secure; HttpOnly
DEBUG: http.client header: content-type: application/json;odata.metadata=minimal;charset=utf-8
DEBUG: http.client header: content-length: 488
DEBUG: http.client header: sap-authenticated: true
DEBUG: http.client header: odata-version: 4.0
DEBUG: http.client header: cache-control: max-age=0
DEBUG: http.client header: sap-server: true
DEBUG: http.client header: sap-perf-fesrec: 59482.000000
DEBUG: http.client header: content-encoding: gzip
DEBUG: http.client header: x-content-type-options: nosniff
DEBUG: http.client header: strict-transport-security: max-age=31536000; includeSubDomains
DEBUG: http.client header: x-xss-protection: 1; mode=block
DEBUG: http.client header: sap-passport-component: none
DEBUG: urllib3.connectionpool https://my123486.s4hana.cloud.sap:443 "GET /sap/opu/odata4/sap/api_product/srvd_a2x/sap/product/0002/ HTTP/1.1" 200 488
DEBUG: URL with appended params: https://my123486.s4hana.cloud.sap/sap/opu/odata4/sap/api_product/srvd_a2x/sap/product/0002/
DEBUG: http.client send: b'GET /sap/opu/odata4/sap/api_product/srvd_a2x/sap/product/0002/$metadata HTTP/1.1\r\nHost: my123486.s4hana.cloud.sap\r\nUser-Agent: FME/2025.7.52.25241 python-requests/2.32.3\r\nAccept-Encoding: gzip, deflate\r\nAccept: */*\r\nConnection: keep-alive\r\nOData-MaxVersion: 4.0\r\nCookie: sap-usercontext=sap-client=100; SAP_SESSIONID_Z5R_100=XXX%3d\r\nAuthorization: Basic XXX\r\n\r\n'
DEBUG: http.client reply: 'HTTP/1.1 400 Bad Request\r\n'
DEBUG: http.client header: content-length: 775
DEBUG: http.client header: etag: W/"20250720003254"
DEBUG: http.client header: content-language: en
DEBUG: http.client header: sap-perf-fesrec: 198967.000000
DEBUG: urllib3.connectionpool https://my123486.s4hana.cloud.sap:443 "GET /sap/opu/odata4/sap/api_product/srvd_a2x/sap/product/0002/$metadata HTTP/1.1" 400 775
DEBUG: URL with appended params: https://my123486.s4hana.cloud.sap/sap/opu/odata4/sap/api_product/srvd_a2x/sap/product/0002/$metadata
OData Reader: Client error was received: '400'. The error message was: 'The version '4.01' is not valid.'
(D:\code\fme\source\engine\plugins\python\fme-odata\src\odata\ODataCommon.py:77) doRequest
(C:\Program Files\FME\python\requests\models.py:1024) raise_for_status
raise HTTPError(http_error_msg, response=self)
(D:\code\fme\source\engine\plugins\python\fme-odata\src\odata\ODataReader.py:534) read
(D:\code\fme\source\engine\plugins\python\fme-odata\src\odata\ODataReader.py:541) _readFeatureGenerator
(D:\code\fme\source\engine\plugins\python\fme-odata\src\odata\ODataReader.py:361) _fetchMetadataForSchema
(D:\code\fme\source\engine\plugins\python\fme-odata\src\odata\ODataCommon.py:129) doRequest
Python Exception <ODataReaderException>: FMEException: 929906: OData Reader: Client error was received: '400'. The error message was: 'The version '4.01' is not valid.'
An error has occurred. Check the logfile above for details
(D:\code\fme\source\engine\core\engine\readrimp.cpp:1102) class StatusInfo __cdecl STFReaderImp::getNextFeaturesFromReader(bool)
(D:\code\fme\source\engine\core\engine\readrimp.cpp:1034) class StatusInfo __cdecl STFReaderImp::getTaggedFeature(class STFFeature *&)
(D:\code\fme\source\engine\core\engine\readrimp.cpp:1116) class StatusInfo __cdecl STFReaderImp::getNextFeaturesFromReader(bool)
(D:\code\fme\source\engine\core\kernel\simptran.cpp:664) class StatusInfo __cdecl STFSimpleTranslator::convert(void)
(D:\code\fme\source\engine\core\engine\stftrans.cpp:128) class StatusInfo __cdecl STFTranslator::translate(void)
Translation FAILED with 2 error(s) and 59 warning(s) (0 feature(s) output)
FME Session Duration: 1.5 seconds. (CPU: 0.6s user, 0.4s system)
END - ProcessID: 27860, peak process memory usage: 90180 kB, current process memory usage: 72884 kB
ERROR : An error has occurred. Check the logfile above for details
ERROR : (D:\code\fme\source\engine\core\engine\readrimp.cpp:1102) class StatusInfo __cdecl STFReaderImp::getNextFeaturesFromReader(bool)
ERROR : (D:\code\fme\source\engine\core\engine\readrimp.cpp:1034) class StatusInfo __cdecl STFReaderImp::getTaggedFeature(class STFFeature *&)
ERROR : (D:\code\fme\source\engine\core\engine\readrimp.cpp:1116) class StatusInfo __cdecl STFReaderImp::getNextFeaturesFromReader(bool)
ERROR : (D:\code\fme\source\engine\core\kernel\simptran.cpp:664) class StatusInfo __cdecl STFSimpleTranslator::convert(void)
ERROR : (D:\code\fme\source\engine\core\engine\stftrans.cpp:128) class StatusInfo __cdecl STFTranslator::translate(void)
ERROR : (D:\code\fme\source\engine\core\kernel\fmetran.cpp:934) class StatusInfo __cdecl FMETranslator::translate(class stk::ex::UStringArray<0>,bool &,bool,const class std::function<bool __cdecl(class ObsoleteString &)> &,bool)
It would be great, if the OData Reader would add support for OData 4.01 in the future.
PierreAtSafe
Forum|alt.badge.img+11
New→Open
