Archived
Add "Force table creation" to list of table handling options
Related products:FME Form
  • February 5, 2020
  • 62 views
lifalin2016
Forum|alt.badge.img+41
This may have been suggested in the past, but I can't seem to find any mentions, and it's still a good idea.
When translating data to a database of any kind, FME will create the needed tables to accomadate the translated data. If no data is processed to a given destination, no tables are created.
So, FME knows how to create the table, but doesn't due to lack of data.
The often proposed work-around (create a dummy feature, and delete it) is really not good, and is more of a hack than a solution.
If an additional option (Force table creation) was available, when the attribute definition is fixed (manual), which is often the case when using "Generate" to create the workspace, transferring a full database would be a much easier task. FME should then just process all writers without data, and create the table if it has a fixed schema.
chriswilson
Forum|alt.badge.img+29
  • February 6, 2020
lifalin2016
  • February 18, 2020
Right you are. I did search, but there are obviously many ways of describing the same feature request, hence I missed it. But it doesn't seem to get much support ?
chriswilson
  • February 21, 2020
All good. There's support but not everyone needs to do this and there's a workaround involving arcpy's truncate method after writing. I'm sure those awesome Safers will get it done in good time :).
