Released
Ability to style column headers in Excel writer
Related products:Integrations
  • Dec 17, 2015 12:00 AM UTC
  • 12 replies
  • 245 views
davideagle
Forum|alt.badge.img+21
Typically if writing out the headers of columns to Excel it is necessary to then open the Excel file manually to define a style for the first row (to make it stand out). Often just making the text bold or apply colour to the column name rather than the whole column, for example. The option to do this on the writer would cut out a post process.
Forum|alt.badge.img+4
  • May 23, 2016 10:24 PM UTC
I agree, this would be reeeeeallllly nice and would save me some headaches. :)
bruceharold
Forum|alt.badge.img+19
  • May 17, 2018 9:42 PM UTC
I vote for this too.
Just needed this now :(
chriswilson
Forum|alt.badge.img+29
  • Sep 5, 2018 2:11 AM UTC
Using a template is a workaround, but this would be neat to add within a workspace.
sunhenry617
  • Sep 11, 2018 7:33 PM UTC
I would like to see this option in FME too.
philippeb
Forum|alt.badge.img+23
  • Nov 9, 2018 4:53 PM UTC
I have like 20 scripts using this... it would be sooo easier!
it would be so much easier than having to use a template especially when you only want to make the headings bold!
  • Jun 11, 2020 2:31 PM UTC
my vote added to this too...very surprised it's not an option currently as I would imagine this is a standard requirement for any spreadsheet; it certainly is where I work. Cheers
dbaldacchino1
Forum|alt.badge.img+14
Ugh, can't believe this is still not available :( I concur that having an option to style the headers separately from the values would be great. The template workaround is not an option if you want to write to the same file multiple times to insert new data since you have to set the parameter "Overwrite Existing File" to "Yes" to expose the template options.
krisvesweco
  • Nov 9, 2021 12:15 PM UTC
I noticed that there is a setting "Format fields name row" in the Xlsx writer now (I noticed in version 2021.1.2 but it might have arrived earlier). However I cant find any documentation on how to use it unfortunately. But the name of the parameter makes me think that it might be related to this idea.
LizAtSafe
Forum|alt.badge.img+26
  • Mar 25, 2024 6:35 PM UTC
In Beta→Released
LizAtSafe
  • Jun 15, 2024 2:57 AM UTC
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/xlsx/XLSX_writer.htm
