Archived
Document PDF Writer
Related products:FME Form
geomancer
danilo_fme
  • geomancer
    geomancer
  • danilo_fme
    danilo_fme
geomancer
The Document PDF Writer package that was published on FME Hub earlier today looks promising.
Unfortunately it can only be installed in FME Build 24783 or higher.
Would it be possible to publish a version of this package for older FME versions?
andreaatsafe
Forum|alt.badge.img+14
Hi ​@geomancer,
We do aim to support older versions of FME wherever possible for packages on FME Hub.
In this case, however, the Document PDF Writer and DocumentPDFStyler transformer rely on features that were only introduced in FME 2024.2. Because of this, the package isn’t compatible with earlier versions.
Thanks for your understanding and your early interest! We hope you get a chance to try it out in a newer version!
andreaatsafe
NewArchived
