Open
Preview Parameter and Attribute values in text/arithmetic editors
Related products:FME Form
  • February 19, 2025
  • 5 views
mgg_beca
Hi there,
It would be great if there was a button at the bottom of the text/arithmetic editors that could substitute their placeholders with any cached values or default values for attributes and user parameters. This could be useful for checking values are correctly formatted before having to run the flow and check that it works correctly.
For example:
Becomes:
you could have different colours for parameters and attribute values, or some other way of differentiating them. Or you could provide mouseover hints that direct the user to the source of the value.
Thanks,
Marc
JennaKAtSafe
Forum|alt.badge.img+7
NewOpen
