Released
Increase/Customise Zoom Level Limit in Geometry Parameter
Related products:FME Flow
barisguner
There is currently a Zoom limit in the Geometry Parameter which prevents users from zooming in further than a specific level like (z21 in Google). A default limit for Google Maps is reasonable but when using own custom WMTS layers users should be able to set this limit. This “feature” of the Leaflet source code behind this function is currently quite “limiting”.
So either the default zoom limit should be adjusted further in Leaflet for custom WMTS layers or users should be given the capability to do so.
LizAtSafe
Forum|alt.badge.img+15
  • August 15, 2024
NewOpen
LizAtSafe
  • April 5, 2025
OpenReleased
LizAtSafe
  • April 5, 2025
The zoom level has been increased to 22 in FME 2024.2+. If this is still not sufficient, please create a new idea with an ideal zoom limit for a specific map tile/layer.
