Open
Improve the HTTPCaller by specifying in the form in the Multipart Upload a column header from "Value" be changed to "Value/MimeType"
Related products:Transformers
  • June 4, 2024
  • 63 views
salvaleonrp
Forum|alt.badge.img+20
Its not obvious but it would be nice to make it easier to see.
Without clicking on the value cell, it looks like a single value parameter.
When I click on the cell, I see both the drop down and the ellipsis menu. Since there is a default value for MIME_TYPE, user would just populate the drop down and can easily ignore the mime-type.
A further enhancement to this would be to make mime_type configured to an Attribute Value choice similar to “value”. If this is available, then I can add a MimeTypeFinder transformer in my workflow to populate the Mime-type parameter of the Multipart Upload.
The use case for this would be when using the AddAttachments REST API and a feature with multiple attachments of different mime types supported by the destination format, eg, AGOL and Portal format writers.
LizAtSafe
Forum|alt.badge.img+18
  • August 6, 2024
NewOpen
salvaleonrp
  • November 10, 2025
Related link: to add a few more upvotes :)
In the HTTPCaller: Make an extra column for MIME Type of multipart upload
