Can you update the API call to enable us to see who ran a job? I am trying to better support my users but I would like to be able to include the user that ran the automation into an email that I receive when a job fails.
In the V4 Flow API, the /jobs
endpoint will return runtimeUserName
. You can apply sourceType=automations
to help filter the results or use sourceID=<Automation UID>
for the specific Automation. The Job id
is also returned to help with filtering the response if that is available to you.
In the V3 Flow API, /transformations/jobs/completed
will provide the same information (and filtering options), though the value is more difficult to parse as runtimeUserName is nested in the response—see documentation for details. An example snippet is below:
"request": {
"NMDirectives": {
"directives":
{ "name": "input_notification",
"value": "{\"source\":\"schedule\",\"time\":\"2024-04-01T17:53:58Z\",\"runtimeUserName\”:\”<username>\”}”
It is definitely easier when using the V4 /jobs endpoint! I’m not sure if it is feasible in your current workflow—so any more information how you are constructing the email body could be helpful.
Hope this helps.
