Setting the number of standard engines requested is not intuitive. There is a sub-job running on engine A:3. In this case, the standard setting is actually 3 on host A and 2 on host B. This is the edit page of requested engines - why is 4 shown on host A and what is the effect if i change it to 3 in this case? (FME Flow 2023.2.1)
I would preferr the subjob engine(s) to be ignored from the server settings in this case - Editing the number of engine setting per engine host is what i expect in this section. Not the current status of them. There could be 0 or 6 of them running - I still have requested 3.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
