Released
Set lineweight of a DWG layer in the DWG Writer
Related products:Integrations
  • March 23, 2023
  • 16 views
jasperwis
Forum|alt.badge.img+19
At the moment, you can set the description, appearance (color and linetype) and the state of a layer in the parameters of the DWG writer(s).
So two layer properties were overlooked here: Lineweight and Transparency.
I would like to see Lineweight added here. Moreover because it's not possible to create a template with correct layer lineweights on beforehand. So I believe there is no way to set the layer lineweight, without having to use a LISP routine/AutoCAD script.
LizAtSafe
Forum|alt.badge.img+18
  • June 15, 2024
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/acad/acad.htm
