Archived
Have "invalid third dimension" feature error from SurfaceDraper specify feature
Related products:Transformers
hzhzlosg
  • hzhzlosg
    hzhzlosg
tcrossman
When running the SurfaceDraper transformer on 3D polygons as the surface, a surface polygon may throw an "invalid third dimension" error/warning. The message, however, does not specify which feature caused the error. It should. For me, anyway, I work with very large datasets, and identifying the offending feature is nigh unto impossible. In fact, I have this problem at this moment, and no amount of geometry checking in either ArcGIS or FME has been able to identify the offending feature. Simply identifying the offending feature in the error message in the logfile would make all the difference.
