Open
FME Server apps to return Errors
Related products:FME Flow
  • September 4, 2020
  • 9 replies
  • 235 views
danilo_fme
warrendev
reedwhit
hakans
  • danilo_fme
    danilo_fme
  • warrendev
    warrendev
  • reedwhit
    reedwhit
  • hakans
    hakans
virtualcitymatt
When using a FME Server App which fails for some reason there is no built in way to return an error message to the user. It is always an unknown problem.
It would be great if there was a way to return a few more details to the user. This is particularly important when an invalid dataset is uploaded.
Without a workaround there is currently no way to let the user know their data needs to be fixed.
warrendev
Forum|alt.badge.img+23
  • September 4, 2020
This would be really helpful!
  • September 24, 2020
great idea !
anderstgd
  • March 19, 2021
Thank you for adding this idea! This is exactly what I was going to suggest.
reedwhit
Forum|alt.badge.img+9
  • April 16, 2021
could you email the log or message the user? when they run a long job.... or have an option to stream the Fatal parts of the log to the browser after the app runs.
thijsknapen
Forum|alt.badge.img+10
  • July 15, 2021
Hi @virtualcitymatt,
I struggled with the same thing. My preferred method would be to use a terminator message with a custom termination message for this. However, in the past it seemed that this termination message would only sometimes be returned to the user, and sometimes the message 'unknown error' would return.
Initially to work around the problem I would write the issues into an 'logged_items' excel and would return this to the user (using the data download service).
However it seems that the terminator issue is resolved in FME 2021.1, so maybe that could also help you out.
mgg_beca
Forum|alt.badge.img+11
  • November 14, 2023
I would love the ability to expose logger transformers to the app user while the app is running so you can log the results of specific processes. that way the user can see progress is being made. you could easily create custom error messages and log these as well. would be so much better than just thisScreenshot 2023-11-14 204025and then maybe something happens or doesn't.
  • January 22, 2024
Giving the specifics of a failure, or the output of loggers/terminators would be invaluable to users of flow apps. As opposed to a simple 'failed' message.
Often users are making simple errors with data inputs and parameters that is causing a lot of unnecessary back and forth. The majority of these issues could be self diagnosed with the ability to view these notifications. This is a significant issue for uptake of our developed apps.
LizAtSafe
Forum|alt.badge.img+15
  • February 10, 2024
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
ecx
Forum|alt.badge.img+4
  • March 31, 2025
This functionality would be extremely useful
for anyone looking for the workaround:
