Released
Expand "Attribute Accumulation" parameters group in the ListExploder by default
The default behavior of the ListExploder in 2015+ is different from 2014 and earlier. Many users expect that the transformer behaves with "Use Incoming List" mode (it's equivalent to the default in 2014), but the current default is "Use Original" in fact. In the Community Answers, I have seen several questions caused by the conflict, and I myself often forget to check this setting too.
The default itself is not an issue. It's the issue that the "Attribute Accumulation" parameters group is not expanded by default.
Hope that the parameters group will be expanded (shown) by default.
