Open
Enable looping to a private input in an FMW file
Related products:FME Form
  • August 19, 2021
  • 22 views
siennaatsafe
danilo_fme
jdh
warrendev
thdrg
  • siennaatsafe
    siennaatsafe
  • danilo_fme
    danilo_fme
  • jdh
    jdh
  • warrendev
    warrendev
  • thdrg
    thdrg
thdrg
I realized that when you're doing a loop inside a linked custom transformer, you don't have the possibility to redirect the loop to a private input. If you do that, you'll have a "LOOPBACK_INPUT_TAG" error.
So you have to publish the input (even if you don't want it to be visible on the custom transformer).
thdrg
Forum|alt.badge.img+11
  • August 20, 2021
Edit : in the title, it should be FMX instead of FMW
