Open
Autocad DWD/DXF Parameters allow Read ALL Paper Spaces beside of manually choose
Related products:Integrations
  • May 24, 2016
  • 30 views
***Note from Migration:***
Original Title was: Autocad DWD/DXF Parameters allow Read ALL Paper Spaces beside of manually choosen ones
When I read several DWG's, I don't know the names of all the Paper Spaces that may be there.
I want to filter the viewports, or reading the Model Space Entities through viewports with Name starting with....
When I read in all DWG's only with all Paper Spaces and without Model Space, then I can read in the right Paper Spaces with a second feature Reader.
gabriel_hirsch
Forum|alt.badge.img+12
This is a show stopper right now. When batch reading DWG-files it's impossible to read paper spaces.
mechomicky_bmcd
Forum|alt.badge.img+4
Came here to add this idea, but found this one in the search. This is a must for a use case we are building out right now of batch extracting title block attributes from DWG files
