Archived
Support for SSH tunnelling to FME Cloud instance
siennaatsafe
danilo_fme
oliver.morris
fgiron
arthur_bazin
+6
  • siennaatsafe
    siennaatsafe
  • danilo_fme
    danilo_fme
  • oliver.morris
    oliver.morris
  • fgiron
    fgiron
  • arthur_bazin
    arthur_bazin
  • krowix
  • jsmitsman
    jsmitsman
  • kheradmandim
  • jstanger
    jstanger
  • eim
  • treborq
oliver.morris
Security restrictions on our current AWS environment imposed by IT mean it is increasingly tricky to get connections to FME Cloud. If we can use SSH Tunnelling that would be a great help. We really only need it for database traffic - if it can be locked down somehow. This is discussed more at length here: https://community.safe.com/s/feed/0D54Q000080hLyhSAE
jstanger
  • November 12, 2020
My personal recommendations would be for FME Cloud or general FME Server instances to use SSH Tunnels as an option similar to Web Connections.
Given the reputation for SSH Tunnels not being stable for long periods of time, particularly when idle, it seems best to impose the limitation that FME Cloud/Server can only work with SSH Tunnels it initiates (probably with public key certs as well to ensure good security practice). This also sidesteps the security risk of exposing/enabling SSH Tunnel connections to FME Cloud/Server from the broader internet. Target server options can then either be a jump server or direct, though most cases would likely require a jump server.
The SSH Tunnel could be treated as a wrapper around an existing Web Connection that then exposes a localhost port for bi-directional communication.
arthur_bazin
Forum|alt.badge.img+12
