Hi everybody,
I would like to be able to share a common list of publish parameters accross several workspaces.
For instance, use the same 10 published parameters name within 66 workspaces. And update new name easily.
To do so, I though to make a list of these 10 parameters name in a txt file (could be any format) and to read this list in all of my 20 workspaces.
I will then compare this list with one of the current workspace parameter. I will use the FME workspace reader to get a list of the current parameters. The comparison of these two lists will allow to dynamically know which publish parameters are already within the workspace.
Then I only miss to have a FME workspace writer to create, on the fly, the missing parameters.
I hope you will find this idea useful, and that you will vote for it :)
All the best,
Aurélien
