Archived
Oracle SDO Writer to use calculated CS extents when creating sdo_geom_metadata e
Related products:FME Form
  • November 22, 2015
  • 13 views
bo
Forum|alt.badge.img+10
***Note from Migration:***
Original Title was: Oracle SDO Writer to use calculated CS extents when creating sdo_geom_metadata entry
When an Oracle spatial table is written, a metadata entry in user_sdo_geom_metadata is created with layer CS extents (Max X Coord, Min X Coord ....) in DIMINFO column taken from "Format Parameters" setting of the Writer Property menu.
I think it will be helpful if FME allows CS extent settings on the "Format Parameters" tab to be OPTIONAL, in which case FME automatically calculate the extents from the source data for use in the created metadata entry.
bo
  • November 22, 2015
the screen capture below shows the Format Parameters setting referenced in the proposed idea.
