Released
Better support for named web connections in FME Server
Related products:FME Form
  • June 9, 2016
  • 14 views
nic_ran
Forum|alt.badge.img+16
In FME Server (2016.1) it is easy enough to manage named database connections. The capability exists on the "Manage Database Connections" page to create a new connection and edit an existing connection.
However, the same cannot be said for named web connections. The only current capability on the Web Connections page is to remove an existing connection. There is no support for editing existing connections or adding new connections.
This problem is compounded by the fact that there is no simple way to sync connections between FME Desktop and FME Server (See my other post: Easy upload of named connections from Desktop to Server).
I would like to see support for named web connections improved in FME Server.
rylanatsafe
Forum|alt.badge.img+14
  • February 9, 2018
HI @nic_ran, thank you very much for suggesting this idea! While tidying up some of the ideas in the FME Server space, I noted that this has been implemented in FME Server 2017.1!
To create a new Web Connection, you must first publish from FME Workbench to upload the 'Web Service/Connection Definition' – note that this can also be completed from the FME Options menu (Web Connections > Manage Web Services).
