Open
A transformer, which combines AttributeValueMapper, AttributeRangeMapper and Tes
Related products:Transformers
siennaatsafe
warrendev
tcrossman
mgg_beca
martinkoch
+3
  • siennaatsafe
    siennaatsafe
  • warrendev
    warrendev
  • tcrossman
    tcrossman
  • mgg_beca
    mgg_beca
  • martinkoch
    martinkoch
  • mpsims
    mpsims
  • mes
  • rchoucroun
    rchoucroun
geolassi
***Note from Migration:***
Original Title was: A transformer, which combines AttributeValueMapper, AttributeRangeMapper and TestFilter
I'm using AttributeValueMapper, AttributeRangeMapper and TestFilter quite a lot, but I'm missing a transformer, which would have similar interface as AttributeValueMapper, but you could set a Test Condition to the source value like in TestFilter. If the value of the source attribute passes the test condition, the destination attribute would get the value from the corresponding Destination Value.
At the moment I usually have a TestFilter with AttributeCreators for each output port of the TestFilter. AttributeValueMapper is a good tool, but lacks the capabilities of TestFilter.
Of course I could use Conditional Values in e.g. AttributeManager, but they're always hidden inside the transformer.
Be the first to reply!
