Archived
Python Interpreter not being completely utilized
Related products:Transformers
  • May 31, 2019
  • 14 views
dellerbeck
Forum|alt.badge.img+7
After upgrading to FME 2019, the Python interpreter is not using the entire package. After setting the interpreter to both the ArcGIS Pro 2.1/2.2/2.3 Pyhon (3.6) and also a custom interpreter pointing at the ArcGIS Pro default env. FME is not returning the correct dateutil package.
This was brought up by trying to import Pandas for use with the Python Caller, an error message of "dateutil minimum release of 2.5.0 required". This is not only on Windows but also on MacOS, the same solution corrected it on both and Pandas does import correctly in Eclipse, ArcGIS Pro, Conda, etc. without error.
Running a Python caller with the following
import fme import fmeobjects import os import dateutil def processFeature(feature):     feature.setAttribute("PyPath",str(os.path))     feature.setAttribute("DateVersion",str(dateutil.__version__))
FME returns
Path (Correct) =
Date Util Version (Incorrect) = 2.4.0
ArcGIS Pro returns
import dateutil print(dateutil.__version__) 2.7.3 import os print(os.path) module 'ntpath' from 'C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\Lib\\ntpath.py'
After searching some, I realized I had to replace the dateutil and python_dateutil-2.4.0.dist-info under "Install PathFME2019python" FME returns
Path (Correct) = module 'ntpath' from 'C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\ntpath.py'
Date Util Version (correct) = 2.7.3
stevenjh
Forum|alt.badge.img+5
  • June 10, 2019
I was having this same issue and found if I set the interpreter to ArcGIS Pro 2.1/2.2/2.3 then created a new workbench I could import Pandas.
