Released
Control the Execution Order of "Starter" Transformers
There are some transformers having no input port, which will be "starter" of the translation in a workspace. e.g. Creator, SQLCreator, PythonCreator etc.
Currently there is no way to explicitly control the executing order of them, but I think it would be useful if users could control the order optionally.
An advantage is that performance (processing time and/or memory usage) of some transformers can be improved if the order of inputs could be controlled correctly. e.g. Clipper: Clippers First, FeatureMerger: Suppliers First, SpatialFilter: Filters First.
Additionally, it would also be useful if there were a workspace parameter that determines which run first, readers or starter transformers.
