Archived
Dynamic page object location in PDF page formatter
Related products:Transformers
  • November 11, 2019
  • 11 views
rylanatsafe
cshepard
siennaatsafe
+30
  • rylanatsafe
    rylanatsafe
  • gerhardatsafe
  • annabelleatsafe
  • cshepard
    cshepard
  • siennaatsafe
    siennaatsafe
  • david_r
  • redgeographics
  • danilo_fme
    danilo_fme
  • jdh
    jdh
  • sigtill
    sigtill
  • tcrossman
    tcrossman
  • davideagle
    davideagle
  • stalknecht
    stalknecht
  • kennyo
    kennyo
  • philippeb
    philippeb
  • mark_f
  • ciarab
    ciarab
  • courtney_m
    courtney_m
  • revesz
    revesz
  • mapperz
  • generationn00b
  • marko
  • ml56067
    ml56067
  • mik_w_thomsen
    mik_w_thomsen
  • jonathan
  • alexbiz
    alexbiz
  • julien
  • bjarne
    bjarne
  • soothsayers
    soothsayers
  • worjak
    worjak
  • voss1
  • jerrodstutzman
  • stewartatsafe
    stewartatsafe
  • laurawatsafe
    laurawatsafe
  • bruran
    bruran
jeroen
Kind of an addition to:
https://knowledge.safe.com/content/idea/18817/pdf-page-formatter-parameters-from-attributes.html
Would love to be able to see some extra options for the Page object location based on values in the attribute table. With the idea that you don't need input ports but can use a generic input port that filters the objects that need placing based on basename, feature type or some kind of group (i.e. map, legend, rasters).
Adding a generic input port where you need to define an attributes for the upper left x, left y, height en width of the object. By doing so all object can be placed in the PDF page mathematically instead of drawing boxes by hand and always have check if the aspect ratio is in order.
deanhowell
Forum|alt.badge.img+23
  • November 14, 2019
I concur, that this sort of functionality would be very useful.
