Archived
Setting sketchup traits for angle between normals.
Related products:Transformers
kidega
Hello,
I wounder if it would be possible to develope feature query of sketchup trait for setting angle between normals and controlling smooth normals and soften coplanar. The intended usage is to write a sketchupfile as a template with buildings and terrain with different angle between normals for visual effect and easer reading of those geometries by controlling visibility of edges on object level. Another trait request, if it's not available already would be to set a sketchup group (geometry name in GeometryPropertySetter) to be locked. Manually done in sketchup by right clicking the group and choose locked. This would also add to the value of a properly set sketchup template written from fme.
Thanks!
