Released
Automations Webhook Authentication
Related products:FME Flow
siennaatsafe
nathanatsafe
danilo_fme
warrendev
+9
  • User1682409324637385798
  • siennaatsafe
    siennaatsafe
  • nathanatsafe
    nathanatsafe
  • danilo_fme
    danilo_fme
  • warrendev
    warrendev
  • martinkoch
    martinkoch
  • antoine
    antoine
  • mark_ocallaghan
  • bjarnefagerbakk
  • fran-gd
    fran-gd
  • brian_dillon
  • neilhellas
  • jobou
  • mtaftferguson
    mtaftferguson
nathanatsafe
I have a requirement that my Webhook Automation can only be triggered by authorized applications, so it would be great if Automations Webhooks supported authentication through header specification. Eg. The request to the Webhook requires an Authorization header key with an FME Server token similar to the FME Server REST API.
This would be a valuable add-on to the FME product for our organization. Although Workspace Webhooks have Authorization header enforcement, I have been unable to pass published parameter values into the workspace in this way. Therefore I would like Webhook Automation to introduce support for Authorization header authentication.
LizAtSafe
Forum|alt.badge.img+15
  • June 15, 2024
https://docs.safe.com/fme/html/FME-Flow/WebUI/Automations-Triggers/Trigger-Webhook.htm
