Workbench to convert any DWF to a DXF
  • Feb 25, 2022 2:38 AM UTC
  • 136 views
nicholas
Forum|alt.badge.img+14
I want to build a workbench (for publishing to a FME Server) that converts any DWF file to a DXF file of the same name. I started by use the Generate Workspace Dialog and ticked Dynamic Schema. However, the name of the output DXF is hardcoded. I would like the name of the output DXF to be the same as the name of the input DWF (with DXF extension). How do I make this work?
jovitaatsafe
Forum|alt.badge.img+11
Hi @nicholas​,
Try setting the 'Fanout Dataset' in your AutoCAD DWG writer to the attribute fme_basename with the extension .dxf. This attribute holds the source dataset's file name without the extension, so you can use it as a dataset fanout to keep the output the same name.
To do this, you'll need to first expose the attribute in your reader feature type parameters by double-clicking the reader feature type, going to Format Attributes, and checking 'fme_basename'. Then in the Writer parameters (right click - edit...), enable Fanout Dataset, select the three dots [...] to open the Text Editor, double click fme_basename and type in .dxf. It'll look something like this in the navigator when you're done:
fanout-datasetHope that gets it working for you as well!
