Why Jobs are not showing in FME Server web UI?
  • February 22, 2017
  • 52 views
The jobs list is empty (running, queued and completed). When a job has finished running (it is possible to see it in the UI) it sits for a few minutes in the interface and then gets automatically deleted. I disabled all cleanups logs for jobs. It seems to be only something related to the interface because if I access C:\\ProgramData\\SafeSoftware\\FME Server\\resources\\logs\\engine\\current\\jobs the actual logs are there but they are simply not showing on the web interface under the "Manage -> Jobs" tab.
Has anyone already experienced this issue?
itay
Forum|alt.badge.img+17
  • February 22, 2017
Not really, any luck logging out and in again?
  • February 23, 2017
Make sure you're not running out of disk space, FME Server can be fairly aggressive about deleting old job entries when disk space is running really low.
Documentation: https://docs.safe.com/fme/2016.1/html/FME_Server_Documentation/Content/WebUI/Cleanup_Files.htm
