Why Jobs are not showing in FME Server web UI?
  • Feb 22, 2017 2:46 PM UTC
  • 103 views
The jobs list is empty (running, queued and completed). When a job has finished running (it is possible to see it in the UI) it sits for a few minutes in the interface and then gets automatically deleted. I disabled all cleanups logs for jobs. It seems to be only something related to the interface because if I access C:\\ProgramData\\SafeSoftware\\FME Server\\resources\\logs\\engine\\current\\jobs the actual logs are there but they are simply not showing on the web interface under the "Manage -> Jobs" tab.
Has anyone already experienced this issue?
itay
Forum|alt.badge.img+19
  • Feb 22, 2017 2:59 PM UTC
Not really, any luck logging out and in again?
  • Feb 23, 2017 8:51 AM UTC
Make sure you're not running out of disk space, FME Server can be fairly aggressive about deleting old job entries when disk space is running really low.
Documentation: https://docs.safe.com/fme/2016.1/html/FME_Server_Documentation/Content/WebUI/Cleanup_Files.htm
