Web Stats / number of logins?
  • Mar 3, 2023 4:23 PM UTC
  • 42 views
jhawks
Forum|alt.badge.img+7
Is there a way thru the admin interface to get number of logins per users? or do we need to check the Tomcat logs?
  • Mar 6, 2023 8:29 AM UTC
I believe the log is your only option. In particular, you may want to check out fmeserver.log, which will mention all logins (FME Server user and client IP).
Forum|alt.badge.img+63
You can build an automation with the Login Failed and Login Succeeded as triggers (you can find those under the FME Server System Events) and then pass that on to a workspace that writes to a logfile (or database).
