Using a workspace on FME Server as the input for an FMW reader
  • Aug 14, 2020 7:18 AM UTC
  • 120 views
Forum|alt.badge.img+54
Is there anyway to read information using an FMW reader about a workspace that has been uploaded to FME Server without downloading first? I can automatically download to a temp location via the API if needed just wanted to check I wasn't missing an alternative
Best answer by nielsgerrits
Not sure if this helps you but I have a workspace on server which reads itself using $(FME_MF_DIR)$(WORKSPACE_NAME).fmw as the path to expose the modified_date and write it to a "processed jobs" table. This way I can reprocess older jobs when the workspace is updated. So at least it works without downloading.
nielsgerrits
Forum|alt.badge.img+67
  • Aug 14, 2020 9:17 AM UTC
itsmatt
Forum|alt.badge.img+48
  • Aug 14, 2020 10:01 AM UTC
Yeah I would think it would work if you have the correct system path. For windows the workspaces are usually stored as
C:\\ProgramData\\Safe Software\\FME Server\\repositories\\<repo_name>\\<workspace_name>\\<workspace_name>.fmw
  • Aug 14, 2020 10:13 AM UTC
Thanks both, i had a typo in the first <workspace_name> in the address - using $(FME_MF_DIR)$(WORKSPACE_NAME).fmw to get the information and copy and pasting sorted it :-)
itsmatt
  • Aug 14, 2020 12:42 PM UTC
Curse those typos!! Typos are the worst!
