Unable to create a workbench directory (error 500)
  • February 12, 2021
  • 6 replies
  • 103 views
smol
Greetings,
Once in a while, our workbench using the "dataupload" service seems to return an error 500. We do not see any logs related to disk space, nor should it as it is only using ~20% of the available space. The following log is shown in the logs of "Resources -> Logs -> service -> current -> fmeserverweb_dataupload.log":
Fri-12-Feb-2021 07:55:46.873 AM   INFORM   http-nio-8080-exec-22   419011 : Creating new request object: path level = "1", requested path = "", session ID = "f257b28e-bdd2-49df-84eb-007d69dabc5e", uploaded files = [], workspace path = "/<repository>/<wb_name>.fmw", retrieve absolute paths = "true", extract files = "false"
java.io.IOException: Unable to create directory: /data/fmeserverdata/resources/system/temp/upload/<repository>/<wb_name>.fmw/f257b28e-bdd2-49df-84eb-007d69dabc5e
at COM.safe.web.upload.StoreManager.setup(StoreManager.java:232)
at COM.safe.web.upload.StoreManager.<init>(StoreManager.java:226)
at COM.safe.web.upload.StoreManager.acquire(StoreManager.java:253)
at COM.safe.webservices.upload.VolatileUploadServlet.doPost(VolatileUploadServlet.java:245)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:661)
at COM.safe.webservices.upload.VolatileUploadServlet.service(VolatileUploadServlet.java:72)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:742)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at COM.safe.webservices.utility.ServiceAuthFilter.doFilter(ServiceAuthFilter.java:64)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.ebaysf.web.cors.CORSFilter.handleNonCORS(CORSFilter.java:640)
at org.ebaysf.web.cors.CORSFilter.doFilter(CORSFilter.java:173)
at COM.safe.webservices.AcceptMIMEAdapterFilter.doFilter(AcceptMIMEAdapterFilter.java:409)
at COM.safe.web.servlet.CharsetEncodingFilter.doFilter(CharsetEncodingFilter.java:541)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:198)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:493)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:650)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:800)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:800)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1471)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
Fri-12-Feb-2021 07:55:46.874 AM   ERROR    http-nio-8080-exec-22   419012 : Request failure, status 500, Unable to create directory: /data/fmeserverdata/resources/system/temp/upload/<repository>/<wb_name>.fmw/f257b28e-bdd2-49df-84eb-007d69dabc5e
 Note, if we try this again it seems to work fine. Is there anything specific reason for this behaviour, or is there a lead that I may follow for debugging?
Best answer by jlutherthomas
This issue occurs when two data upload tasks occur at the same time/very close together, which results in a both requests trying to make a folder at the same time (which fails, as seen in the log file). At the moment, the best 'workaround' is for the user that experiences a failed upload is to try again.
This has been filed as FMESERVER-16637 if anyone else experiences this.
hkingsbury
Forum|alt.badge.img+67
  • February 14, 2021
The fact its saying that it can't create a directory suggest to me that the service account running FME Server doesn't have permissions to do so. However the fact that its only happening sporadically complicates things.
have a look here: https://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/Running_System_Services_Under_Different_Accounts.htm
smol
  • February 22, 2021
Thanks for your comment. Sadly, as you also mentioned, it indeed works when retrying with exact same `POST`. The users of FME Core and FME Server are running with exact same `UID` (Using the FME Docker setup) and can correctly write files to the shared file.
hkingsbury
  • February 22, 2021
Hmmm, never really used Docker so i'm running out of ideas. Have you opened a support ticket?
smol
  • April 13, 2021
Thank you for the investigation. The workaround is sufficient enough for now.
Last question, what is the process of these (internal) tickets? Is there a way for us to follow this ticket (FMESERVER-16637) about the discussion, or is the fully private and internal process?
Yes, tickets are private, but if you (or anyone else) wants to know the status of it you can ask us and with that reference number it's faster for us to look it up.
Also, as you raised a support case your case is linked to that issue internally, so you will get an automated email when it's fixed and what build of FME it's fixed in. If any other customer experiences this and would also like to get notified, they can create a support case, reference that issue number and we can link their case too.
