Sentinel-2 on AWS returns Cannot find Query_Options.Band_List error
  • March 30, 2017
  • 7 replies
  • 27 views
zzupljanin
Forum|alt.badge.img+5
basically I can't get any data (even preview) with this reader. I defined utm zones for my region and always get this error:
SENTINEL2 reader: Cannot find Query_Options.Band_List
What to do? Where to define this query?
jdh
Forum|alt.badge.img+40
  • March 30, 2017
Can you post a screenshot of your reader parameter settings?
itay
Forum|alt.badge.img+18
  • March 30, 2017
Are you using the options provided by the reader for the settings ? or typing them yourself?
stewartatsafe
Forum|alt.badge.img+9
I think we might have an issue. I am seeing that error too. I will look into it and get back to you.
stewartatsafe
I have confirmed this was an issue but it has been fixed. There was a change of format that wasn't supported by the underlying GDAL library in FME. You will need to download FME 2017.1 to get the fix.
fmelizard
Forum|alt.badge.img+21
  • March 31, 2017
As an alternative to @stewartharper's if you're not to keen to try out the beta. If you specify a date range in the reader that is no later than August or July of 2016 it should read in these OK. The format of the service changed around then.
zzupljanin
  • March 31, 2017
Thank you for your answers. Looking forward to check this in FME 2017.1
Cheers
zzupljanin
  • April 3, 2017
Unfortunatelly for my area even that doesn't work.
