Published workspace > workspace app. Won't let me upload data
  • Jan 23, 2024 5:26 PM UTC
  • 126 views
havmoejbv
Forum|alt.badge.img+16
I have a number of workspaces to allow users to convert data between various formats. After upgrading our server to Flow from Server 2023 I had to republish these to get them to work, and for the most part it seems ok. I register each workspace with the job submitter and data download services, and use $(FME_MF_DIR) for temp storage of the uploaded data.
So far so good...
Then there is that one workspace: It is defined the same way as the others, but this will not allow me to select "User Can Upload" when I define the workspace app. The other apps I set up with Service: Data Download and check User Can Upload. For this one workspace the option is not there unless I choose Service: Job Submitter, but then I am not able to download the results.
I can run the workspace manually in Flow, upload files and get a download link to the results, but can't get it to work as an app
Any ideas to what this can be?
havmoejbv
  • Feb 26, 2024 2:41 PM UTC
It seems we may have found the answer to the above problem. It appears to have been a bugfix between Flow 2023.1.1.1 (the version we have installed) and 2023.2.1 that fixes the problem.
We have tested and confirmed that the workspace will publish as a workspace app in Flow 2023.2.1.
