I drop files in FME server (upload) but these files can not be read in the job
  • Aug 16, 2019 1:53 PM UTC
  • 54 views
brigousse
DESIGN READER: Error opening Design file RECOLEMENT BT 17-110_4S1_sig.4S1
The same files are properly processed if it's one of my colleagues who drops it
Nb: he is in the company premises and I work from home
Β
je depose des fichiers par FME server (upload) mais ces fichiers n'arrivent pas Γ  Γͺtre lu dans le job
Β
Les mΓͺme fichiers sont correctement traitΓ©s si c'est un de mes collΓ¨gues qui le dΓ©pose
Nb : il est dans les locaux de l'entreprise et je travaille de chez moi
Β
Β
Β
philippeb
Forum|alt.badge.img+23
  • Aug 16, 2019 3:10 PM UTC
Looks like a permission problem. What's your files path? Try using UNC path.
I suggest you write everything in English ;) Mais vive la France!
fmelizard
Forum|alt.badge.img+22
  • Aug 16, 2019 9:07 PM UTC
Hi @fred-veremes and @rbomme. Wanted to let you know about this query from Thierry of Etudis. Maybe you have another suggestion as well? Thank you!
alexbiz
Forum|alt.badge.img+35
  • Aug 19, 2019 6:19 AM UTC
Hi Thierry, can you share your job log file as well as your workspace and the file(s) you try to process? This will help us identify the issue.
