How to edit FME Server App CSS style?
  • Sep 20, 2021 9:16 PM UTC
  • 150 views
skime
I would like to remove the scrollbar from the FME Server App website. To achieve such action I need to edit FME Server App HTML and CSS code. Is this even possible?
Best answer by redgeographics
The files live somewhere in the FME Server installation directories (although I'm not sure where) so theoretically it would be possible.
If you do it that way you're changing it for all FME Server Apps though, so be careful. I'd also recommend backing up any files you change, just in case.
It might be better to build your own web app using Rest API calls to talk to FME Server.
Forum|alt.badge.img+63
