How to configure FME Server Engine on Docker to use system proxy (Linux)
skime
I'm hosting FME Server Engine using docker on Ubuntu (tag: 21302). When I try to use it and my Ubuntu is connected to a proxy, HTTPCaller in one of the workspaces can't make external requests resulting in:
154	2021-10-24 21:51:39 | HTTPCaller_2 (HTTPFactory): An error occurred while accessing the URL 'https://www.google.com'
155	2021-10-24 21:51:49 | HTTPCaller (HTTPFactory): [5]: HTTP transfer error: Couldn't resolve host name
156	2021-10-24 21:51:49 | HTTPCaller (HTTPFactory): [5]: Please ensure that your network connection is properly set up
157	2021-10-24 21:51:49 | HTTPCaller (HTTPFactory): [5]: No proxy settings have been entered. If you require a proxy to access external URLs, please ensure the appropriate information has been entered
How can I configure the docker FME Server Engine to use the system proxy? I saw the admin guide but it's intended for direct system installation. Are there any environment variables I can set up?
Interesting observation - I had an FME Server Engine on Windows 11 (also on docker WSL2) and it used system proxy without any issues.
virtualcitymatt
Forum|alt.badge.img+35
This in not the full answer, however, when working and debugging proxies in FME a helpful thing to do is enable debug logging. The HTTPCaller is one of the only tools where I find debug logging actually helps.
As far as I can see there are no obvious environment variables for configuring this. You can try and add the steps in the admin guide as a new layer in another dockerfile and use that. Or experiment to see if you can get this to work.
Perhaps Docker has a solution for this: https://docs.docker.com/network/proxy/#configure-the-docker-client
I'm not sure is this is what you're after, however, worth investigating - it could just be that simple
skime
  • October 28, 2021
Thank you virtualcitymatt for the answer, what simply worked for me was setting the HTTP_PROXY and HTTPS_PROXY env variables in docker-compose file under engine container:
environment:
      - HTTP_PROXY=http://${external_ip}:80
      - HTTPS_PROXY=https://${external_ip}:443
external_ip variable is set on my host Ubuntu. Unfortunately if you change proxy address on host/system, you have to restart the engine docker container for reloading the environmental variables.
