How to change ownership of a workspace?
  • March 10, 2021
  • 372 views
User has a workspace in a repo owned by them. How can I change the owner?
Under items under user management I can not see category workspace.
keziaatsafe
Forum|alt.badge.img+8
  • August 30, 2022
Hi @garnet​ ,
Apologies for the late response. You may already have an answer by now but I'd like to share a response for visibility. The security model for FME Server does not track ownership at the workspace-level yet. FME Server only allows the change of ownership for Repositories and not individual Workspaces. You can re-assign ownership of Repositories in the FME Server Web Interface: User Management > Items > Repositories. If you remove or delete a user from FME Server, you'll also be prompted to transfer ownership of the items they own.
Here is a similar idea on FME Community. Please vote on this idea and comment your use case if this is something you're interested in.
Thanks,
Kezia
