How to allow machines on my LAN access to my FME Server??
  • Aug 22, 2020 6:54 AM UTC
  • 123 views
benvk
Forum|alt.badge.img+8
I am currently working through the FME Server Tutorials, it is a very steep learning curve as I have only just installed FME Server on my PC and had zero server experience before now.
So I have it up and running, and I have several other devices connected to the same local network, and I am wanting to log into this server using another machine, but it is as though the server does not exist! the link can be accessed fine from the same machine, its just other machines that cannot access it ("Page not found")
I have double checked, I can successfully ping the machine, no worries at all.
So I have used the 'direct link' on another machine on my network (just replaced localhost:80 with 192.168.1.2), but it is returning a page not found.
http://192.168.1.2/fmeserver/#/workspaces/run/Training/SelfServe-Ex1-Complete.fmw/fmedatadownload
Any thoughts on what may be going wrong here?
                               Publish Summary
FME Server URL               : http://localhost:80
Username                     : admin
Repository                   : Training
Direct Link                  : http://localhost:80/fmeserver/#/workspaces/run/Training/SelfServe-Ex1-Complete.fmw
Uploaded Resources           : C:\FMEData2019\Data\Orthophotos\06-07-LM.tif
Registered Services          : Data Download
                               Job Submitter
Included Writers in Download : Training [JPEG]
Included Writers in Stream   : Training [JPEG]
Time                         : Sat Aug 22 16:44:48 2020
Best answer by takashi
Hi, is the port #80 opened?
mark2atsafe
Forum|alt.badge.img+59
Can you try to ping the server from the client machine in a command window? That might help to show if a connection is possible.
You could also try 192.168.1.2:80 to ensure the right port is being used.
benvk
  • Aug 24, 2020 10:42 PM UTC
Hi Mark,
As mentioned the ping from secondary PC to 192.168.1.2 it works fine.
I then try ping 192.168.1.2:80, and I get 'please check the name and try again'.
Yet if I navigate to 192.168.1.2:80 on my host it opens the fme server interface no worries.
  • Aug 26, 2020 12:09 PM UTC
benvk
  • Aug 26, 2020 12:23 PM UTC
So I made an assumption that the firewall allowed local machines to access each other, as they are all on the 'private network'. After a quick google search, I added port 80 to be an acceptable inbound port for local machines, and now it works perfectly. Very happy as its working as expected!
thanks heaps for the suggestion!
