How do I specify an Azure Container name as a schedule parameter?
  • May 12, 2022 2:13 PM UTC
  • 112 views
mfrancioni
I am using the AzureBlobStorageConnector in my workbench, which takes as a parameter a "Container" value.
I have been using just the name of the container, which is a published string parameter. This works when running the workbench locally as well as when running it from the FME server interface.
My issue is when I attempt to create a "Repeat on Interval" schedule; for this parameter, when I enter the container name as a string value, I get the following error and the schedule cannot be created:
Unexpected value "["containername"]" for parameter "value", expected scalar
Is this expected behaviour? Is there another format I am supposed to enter this name in instead?
mathiku
Forum|alt.badge.img+8
  • Nov 15, 2022 2:35 PM UTC
I have the same problem. Not very descriptive error.
keziaatsafe
Hi @mathiku​ & @mfrancioni​ ,
This does sound buggy and may be best handled in a support case. You can submit a support case here.
There was a similar issue with the OneDriveConnector where the Object ID user parameter cannot be saved in schedules. The workaround was to manually create a "Text" User parameter and use it in the Object ID parameter. Please try using a different parameter type as a workaround.
Hope this helps!
Kezia
