Having issues creating areas from lines
  • November 5, 2021
  • 6 views
When receiving input from a .dgn file a lot of it's parts are seen as Lines (That is how Smart Solids appear in it, almost as a WireFrame), I managed to group them and I am trying to build areas from them which I can later pass to a MeshBuilder.
Some of these lines seem to form perfect forms, just as I wish but some are deformed despite the wireframe looking just as good as the others.
I am grouping my lines by igds_cell_sequence_number, which gives me sort of individual elements like walls/windows/etc. as a wireframe:imageThen I pass it to an AreaBuilder
imageBut my output looks like this:
image.pngIt seems to connect just that triangle over there, how could I change this?
Or any idea of a different approach would be greatly appreciated.
Thanks in advance!
ronnie.utter
Forum|alt.badge.img+11
  • November 8, 2021
Hello, Can you add your workspace here with annotations what you want to accomplish and I/others will/can try to look into it.
