Get JSON file contents using API
  • Mar 25, 2021 1:21 PM UTC
  • 6 replies
  • 123 views
fikusas
Forum|alt.badge.img+5
I'm submitting jobs using FME API (v2):
/transformations/commands/submit/< repository >/< workspace >
The model writes output results to JSON file. Is it a way to get contents of the result JSON file through API request? Using this with no luck (visible log details only):
/transformations/jobs/id/< jobid >/result
jdh
Forum|alt.badge.img+41
  • Mar 25, 2021 7:17 PM UTC
fikusas
  • Mar 26, 2021 7:46 AM UTC
It doesn't helps much.
jdh
  • Mar 26, 2021 2:58 PM UTC
If you publish your workspace to use the data streaming service, and use a webhook, you are returned the actual json. As far as I know that isn’t available through the REST API, there’s an idea for that https://community.safe.com/s/idea/0874Q000000TkprQAC/detail
fikusas
  • Mar 29, 2021 6:39 AM UTC
So basically there is no way to do that using API ?
fikusas
  • Apr 2, 2021 10:09 AM UTC
Can you explain this part?
jdh
  • Apr 5, 2021 4:43 PM UTC
There's an article about webhooks at https://community.safe.com/s/article/webhooks-and-fme-server
