FME server not using the correct ArcGIS license
  • Nov 22, 2022 5:16 PM UTC
  • 0 replies
  • 27 views
swach
I have an issue with FME Server not using the correct ESRI license. I have many workbenches running on my server that require a PRO license, all of them are running successfully except one. One of these workbenches had been running fine until a few days ago when it started requesting a ArcGIS 10.8 license instead of Pro. It will sometimes grab the correct license and run successfully but not usually. I have checked the python compatibility and all of them are set to FME Python 3.8+. I have checked and nothing has changed on our servers or with any of the workbenches.
We are using FME Server 2021.2.6.
